vserver peer transition show
Display transition peer relationships.
The vserver peer transition show command displays the following information about transition peer transition relationships:
Local Vserver name
Source 7-Mode system
Multi-path address
Local LIFs
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-local-vserver <vserver name>]- Local Vserver name
If this parameter is specified, the command displays transition peer information about the specified local Vserver.
- [-src-filer-name <text>]- Source 7-Mode system
If this parameter is specified, the command displays transition peer information about the specified source 7-Mode system.
- [-multi-path-address <text>]- Additional address for source 7-Mode system
If this parameter is specified, the command displays information about the specified multipath-address.
- [-local-lifs <lif-name>,…]- List of Local LIFs
If this parameter is specified, the command displays information about the specified local LIFs.
cluster1::> vserver peer transition show
Vserver  Source Filer  Multi Path Address    Local LIFs
vs1.example.com                              lif1, lif2
          src1.example.com
                        src1-e0b.example.com
 PDFs
PDFs
