vserver peer transition show
Display transition peer relationships.
The vserver peer transition show
command displays the following information about transition peer transition relationships:
Local Vserver name
Source 7-Mode system
Multi-path address
Local LIFs
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-local-vserver <vserver name>]
- Local Vserver name-
If this parameter is specified, the command displays transition peer information about the specified local Vserver.
[-src-filer-name <text>]
- Source 7-Mode system-
If this parameter is specified, the command displays transition peer information about the specified source 7-Mode system.
[-multi-path-address <text>]
- Additional address for source 7-Mode system-
If this parameter is specified, the command displays information about the specified multipath-address.
[-local-lifs <lif-name>,…]
- List of Local LIFs-
If this parameter is specified, the command displays information about the specified local LIFs.
cluster1::> vserver peer transition show Vserver Source Filer Multi Path Address Local LIFs ------- ------------ ----------------- ---------------- vs1.example.com lif1, lif2 src1.example.com src1-e0b.example.com
