vserver consistency-group detach
Detach a child consistency group from an existing parent consistency group
The vserver consistency-group detach command can be used to detach a child consistency group from its parent, to be on its own. If this was the only child under that parent, the parent consistency group will be deleted.
-vserver <Vserver Name>- Vserver Name-
This parameter specifies the Vserver that contains the consistency group that is to be detached.
-parent-consistency-group <text>- Parent Consistency Group Name-
This parameter specifies the parent consistency group.
-consistency-group <text>- Consistency Group to Detach-
This parameter specifies the consistency group that is to be detached.
[-new-name <text>]- New name for the Detached Consistency Group-
This parameter optionaly specifies a new name for the detached consistency group.
The following command detaches the consistency group childCG from its parent Consistency Group parentCG in Vserver vs0, which is renamed to singleCG at removal.
cluster1::> vserver consistency-group detach -vserver vs0 -parent-consistency-group parentCG -consistency-group childCG -new-name singleCG
(vserver consistency-group detach)
[Job 174] Job succeeded: Success
