system switch ethernet log modify
Modify the Ethernet switch log request.
The system switch ethernet log modify command modifies the log request of the specified Ethernet switch.
- -device <text>- Switch Name
Specifies the Ethernet switch device for which the log request is being made. Note: the device must be one of the devices listed as an Ethernet switch from the system switch ethernet show command. The full device name from the system switch ethernet show command must be used.
- [-log-request {true|false}]- Requested Log
Specifies the initiation of a switch log retrieval for the specified Ethernet switch if set to true.
cluster1::> system switch ethernet log modify -device switch-name01(Switch---SN) -log-request true
Modifies the log request for the specified Ethernet switch. Setting the log-request to true initiates an Ethernet switch log retrieval for the specified switch.
 PDFs
PDFs
