system switch ethernet log modify
Modify the Ethernet switch log request.
The system switch ethernet log modify command modifies the the enablement and status of the hourly collection of periodic data and the status of the collection of detailed support logs.
-device <text>- Switch Name-
Ethernet switch device for which the log request is being made.
The device must be one of the devices listed as an Ethernet switch from the system switch ethernet show command. The full device name from the system switch ethernet show command must be used. [-support-requested {true|false}]- Support Log Requested-
Request (true) or cancel (false) support log collection.
[-periodic-enabled {true|false}]- Periodic Log Enabled-
Enable (true) or disable (false) periodic log collection.
cluster1::> system switch ethernet log modify -device switch-name01(Switch---SN) -periodic-enabled true
Enables periodic log collection for the specified Ethernet switch.
