The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system snmp contact
PDF of this doc site
Creating your file...
Your file is ready
Displays or modifies contact details
Sets the contact name as the System.sysContact.0 MIB-II variable.
[-contact <text>]
- Contact-
Specifies the contact name. Without any value specified, this command displays current setting of contact name.
The following example sets the contact name for SNMP. +
cluster1::> system snmp contact -contact private uster1::> system snmp show contact: private location: NB authtrap: 1 init: 0 traphosts: - community: - -
