The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
security protocol ssh show
PDF of this doc site
Creating your file...
Your file is ready
Show the SSH configuration
The security protocol ssh show
command displays the cluster-wide SSH configuration in advanced privilege mode. Use the security protocol ssh modify command to change the SSH configuration that the cluster supports.
The following example displays cluster-wide SSH configuration:
cluster1::*> security protocol ssh show Per-Source Limit: 32 Maximum Number of Instances: 64 Connections Per Second: 10
