- ONTAP 9.14.1 commands
- exit
- history
- man
- redo
- rows
- set
- top
- up
- application commands
- autobalance commands
cluster commands
- cluster add-node-status-clear-failed
- cluster add-node
- cluster create
- cluster join
- cluster modify
- cluster ping-cluster
- cluster remove-node
- cluster setup
- cluster show
- cluster agent commands
- cluster contact-info commands
cluster controller-replacement commands
- cluster controller-replacement network displaced-interface delete
- cluster controller-replacement network displaced-interface restore-home-node
- cluster controller-replacement network displaced-interface show
- cluster controller-replacement network displaced-vlans delete
- cluster controller-replacement network displaced-vlans restore
- cluster controller-replacement network displaced-vlans show
- cluster date commands
- cluster ha commands
- cluster identity commands
cluster image commands
- cluster image cancel-update
- cluster image pause-update
- cluster image resume-update
- cluster image show-update-history
- cluster image show-update-log-detail
- cluster image show-update-progress
- cluster image update
- cluster image validate
- cluster image package delete
- cluster image package get
- cluster image package show-repository
- cluster kernel-service commands
- cluster log-forwarding commands
cluster peer commands
- cluster peer create
- cluster peer delete
- cluster peer modify-local-name
- cluster peer ping
- cluster peer show
- cluster peer connection show
- cluster peer health show
- cluster peer offer cancel
- cluster peer offer modify
- cluster peer offer show
- cluster peer policy modify
- cluster peer policy show
- cluster quorum-service commands
- cluster ring commands
- cluster statistics commands
cluster time-service commands
- cluster time-service ntp key create
- cluster time-service ntp key delete
- cluster time-service ntp key modify
- cluster time-service ntp key show
- cluster time-service ntp security modify
- cluster time-service ntp security show
- cluster time-service ntp server create
- cluster time-service ntp server delete
- cluster time-service ntp server modify
- cluster time-service ntp server reset
- cluster time-service ntp server show
- cluster time-service ntp status show
event commands
- event catalog commands
- event config commands
- event filter commands
- event log commands
event notification commands
- event notification create
- event notification delete
- event notification modify
- event notification show
- event notification destination create
- event notification destination delete
- event notification destination modify
- event notification destination prepare-for-revert
- event notification destination show
- event notification history show
- event role-config commands
- event status commands
- job commands
lun commands
- lun convert-from-namespace
- lun create
- lun delete
- lun maxsize
- lun modify
- lun move-in-volume
- lun resize
- lun show
- lun bind commands
- lun copy commands
lun igroup commands
- lun igroup add
- lun igroup bind
- lun igroup create
- lun igroup delete
- lun igroup disable-aix-support
- lun igroup modify
- lun igroup remove
- lun igroup rename
- lun igroup show
- lun igroup unbind
- lun igroup initiator add-proximal-vserver
- lun igroup initiator modify
- lun igroup initiator remove-proximal-vserver
- lun igroup initiator show
- lun import commands
- lun mapping commands
- lun move commands
- lun persistent-reservation commands
- lun portset commands
- lun transition commands
metrocluster commands
- metrocluster configure
- metrocluster heal
- metrocluster modify
- metrocluster remove-dr-group
- metrocluster show
- metrocluster switchback
- metrocluster switchover
metrocluster check commands
- metrocluster check disable-periodic-check
- metrocluster check enable-periodic-check
- metrocluster check run
- metrocluster check show
- metrocluster check aggregate show
- metrocluster check cluster show
- metrocluster check config-replication show-aggregate-eligibility
- metrocluster check config-replication show-capture-status
- metrocluster check connection show
- metrocluster check lif repair-placement
- metrocluster check lif show
- metrocluster check node show
- metrocluster check volume show
- metrocluster config-replication commands
metrocluster configuration-settings commands
- metrocluster configuration-settings show-status
- metrocluster configuration-settings calibration measure
- metrocluster configuration-settings calibration show
- metrocluster configuration-settings connection check
- metrocluster configuration-settings connection connect
- metrocluster configuration-settings connection disconnect
- metrocluster configuration-settings connection show
- metrocluster configuration-settings dr-group create
- metrocluster configuration-settings dr-group delete
- metrocluster configuration-settings dr-group show
- metrocluster configuration-settings interface create
- metrocluster configuration-settings interface delete
- metrocluster configuration-settings interface show
- metrocluster configuration-settings mediator add
- metrocluster configuration-settings mediator remove
- metrocluster configuration-settings mediator show
- metrocluster interconnect commands
- metrocluster node commands
- metrocluster operation commands
- metrocluster transition commands
- metrocluster vserver commands
network commands
- network ping
- network ping6
- network test-path
- network traceroute
- network traceroute6
- network arp commands
network bgp commands
- network bgp config create
- network bgp config delete
- network bgp config modify
- network bgp config show
- network bgp defaults modify
- network bgp defaults show
- network bgp peer-group create
- network bgp peer-group delete
- network bgp peer-group modify
- network bgp peer-group rename
- network bgp peer-group show
- network bgp vserver-status show
- network cloud commands
- network connections commands
- network device-discovery commands
- network fcp commands
network interface commands
- network interface create
- network interface delete
- network interface migrate-all
- network interface modify
- network interface rename
- network interface revert
- network interface show
- network interface start-cluster-check
- network interface capacity show
- network interface capacity details show
- network interface check cluster-connectivity show
- network interface check cluster-connectivity start
- network interface check failover show
- network interface dns-lb-stats show
- network interface failover-groups add-targets
- network interface failover-groups create
- network interface failover-groups delete
- network interface failover-groups modify
- network interface failover-groups remove-targets
- network interface failover-groups rename
- network interface failover-groups show
- network interface lif-weights show
- network interface service show
- network interface service-policy add-service
- network interface service-policy clone
- network interface service-policy create
- network interface service-policy delete
- network interface service-policy modify-service
- network interface service-policy remove-service
- network interface service-policy rename
- network interface service-policy restore-defaults
- network interface service-policy show
- network ipspace commands
- network ndp commands
network options commands
- network options cluster-health-notifications modify
- network options cluster-health-notifications show
- network options detect-switchless-cluster modify
- network options detect-switchless-cluster show
- network options ipv6 modify
- network options ipv6 show
- network options load-balancing modify
- network options load-balancing show
- network options multipath-routing modify
- network options multipath-routing show
- network options port-health-monitor disable-monitors
- network options port-health-monitor enable-monitors
- network options port-health-monitor modify
- network options port-health-monitor show
- network options send-soa modify
- network options send-soa show
- network options switchless-cluster modify
- network options switchless-cluster show
network port commands
- network port delete
- network port modify
- network port show-address-filter-info
- network port show
- network port broadcast-domain add-ports
- network port broadcast-domain create
- network port broadcast-domain delete
- network port broadcast-domain merge
- network port broadcast-domain modify
- network port broadcast-domain move
- network port broadcast-domain remove-ports
- network port broadcast-domain rename
- network port broadcast-domain show
- network port broadcast-domain split
- network port ifgrp add-port
- network port ifgrp create
- network port ifgrp delete
- network port ifgrp remove-port
- network port ifgrp show
- network port reachability repair
- network port reachability scan
- network port reachability show
- network port vip create
- network port vip delete
- network port vip show
- network port vlan create
- network port vlan delete
- network port vlan show
- network qos-marking commands
- network route commands
- network subnet commands
- network test-link commands
- network tuning commands
- protection-type commands
qos commands
- qos adaptive-policy-group commands
- qos policy-group commands
- qos settings commands
qos statistics commands
- qos statistics characteristics show
- qos statistics latency show
- qos statistics performance show
- qos statistics resource cpu show
- qos statistics resource disk show
- qos statistics volume characteristics show
- qos statistics volume latency show
- qos statistics volume performance show
- qos statistics volume resource cpu show
- qos statistics volume resource disk show
- qos statistics workload characteristics show
- qos statistics workload latency show
- qos statistics workload performance show
- qos statistics workload resource cpu show
- qos statistics workload resource disk show
- qos workload commands
- san commands
security commands
- security snmpusers
security anti-ransomware commands
- security anti-ransomware volume disable
- security anti-ransomware volume dry-run
- security anti-ransomware volume enable
- security anti-ransomware volume pause
- security anti-ransomware volume resume
- security anti-ransomware volume show
- security anti-ransomware volume attack clear-suspect
- security anti-ransomware volume attack generate-report
- security anti-ransomware volume attack-detection-parameters modify
- security anti-ransomware volume attack-detection-parameters show
- security anti-ransomware volume auto-switch-to-enable-mode show
- security anti-ransomware volume event-log modify
- security anti-ransomware volume event-log show
- security anti-ransomware volume space show
- security anti-ransomware volume workload-behavior clear-surge
- security anti-ransomware volume workload-behavior show
- security anti-ransomware volume workload-behavior update-baseline-from-surge
- security anti-ransomware vserver event-log modify
- security anti-ransomware vserver event-log show
- security audit commands
security certificate commands
- security certificate azure-install
- security certificate create
- security certificate delete
- security certificate generate-csr
- security certificate install
- security certificate print
- security certificate rename
- security certificate show-generated
- security certificate show-truststore
- security certificate show-user-installed
- security certificate sign
- security certificate ca-issued revoke
- security certificate ca-issued show
- security certificate config modify
- security certificate config show
- security certificate truststore check
- security certificate truststore clear
- security certificate truststore load
- security config commands
- security cryptomod-fips commands
security ipsec commands
- security ipsec show-ikesa
- security ipsec show-ipsecsa
- security ipsec ca-certificate add
- security ipsec ca-certificate remove
- security ipsec ca-certificate show
- security ipsec config modify
- security ipsec config show
- security ipsec policy create
- security ipsec policy delete
- security ipsec policy modify
- security ipsec policy show
security key-manager commands
- security key-manager delete-key-database
- security key-manager delete-kmip-config
- security key-manager prepare-to-downgrade
- security key-manager setup
- security key-manager show-key-store
- security key-manager update-passphrase
- security key-manager config modify
- security key-manager config show
- security key-manager external add-servers
- security key-manager external disable
- security key-manager external enable
- security key-manager external modify-server
- security key-manager external remove-servers
- security key-manager external restore
- security key-manager external show-status
- security key-manager external aws check
- security key-manager external aws disable
- security key-manager external aws enable
- security key-manager external aws rekey-external
- security key-manager external aws rekey-internal
- security key-manager external aws restore
- security key-manager external aws show
- security key-manager external aws update-credentials
- security key-manager external azure check
- security key-manager external azure create-config
- security key-manager external azure disable
- security key-manager external azure enable
- security key-manager external azure rekey-external
- security key-manager external azure rekey-internal
- security key-manager external azure restore
- security key-manager external azure show
- security key-manager external azure update-client-secret
- security key-manager external azure update-credentials
- security key-manager external gcp check
- security key-manager external gcp disable
- security key-manager external gcp enable
- security key-manager external gcp rekey-external
- security key-manager external gcp rekey-internal
- security key-manager external gcp restore
- security key-manager external gcp show
- security key-manager external gcp update-credentials
- security key-manager key create
- security key-manager key delete
- security key-manager key migrate
- security key-manager key query
- security key-manager key key-table create
- security key-manager key key-table delete
- security key-manager key key-table modify
- security key-manager key key-table show
- security key-manager keystore delete
- security key-manager keystore enable
- security key-manager keystore show
- security key-manager onboard disable
- security key-manager onboard enable
- security key-manager onboard show-backup
- security key-manager onboard sync
- security key-manager onboard update-passphrase
- security key-manager onboard verify-backup
- security key-manager policy show
security login commands
- security login create
- security login delete
- security login expire-password
- security login lock
- security login modify
- security login password-prepare-to-downgrade
- security login show
- security login unlock
- security login whoami
- security login banner modify
- security login banner show
- security login domain-tunnel create
- security login domain-tunnel delete
- security login domain-tunnel modify
- security login domain-tunnel show
- security login duo create
- security login duo delete
- security login duo modify
- security login duo show
- security login duo group create
- security login duo group delete
- security login duo group modify
- security login duo group show
- security login motd modify
- security login motd show
- security login publickey create
- security login publickey delete
- security login publickey load-from-uri
- security login publickey modify
- security login publickey show
- security login rest-role create
- security login rest-role delete
- security login rest-role modify
- security login rest-role show
- security login rest-role expanded-rest-roles modify
- security login rest-role expanded-rest-roles show
- security login role create
- security login role delete
- security login role modify
- security login role prepare-to-downgrade
- security login role show-ontapi
- security login role show-rest
- security login role config modify
- security login role config reset
- security login role config show
- security login totp create
- security login totp delete
- security login totp modify
- security login totp show
security multi-admin-verify commands
- security multi-admin-verify modify
- security multi-admin-verify show
- security multi-admin-verify approval-group create
- security multi-admin-verify approval-group delete
- security multi-admin-verify approval-group modify
- security multi-admin-verify approval-group replace
- security multi-admin-verify approval-group show
- security multi-admin-verify request approve
- security multi-admin-verify request create
- security multi-admin-verify request delete
- security multi-admin-verify request show-pending
- security multi-admin-verify request veto
- security multi-admin-verify rule create
- security multi-admin-verify rule delete
- security multi-admin-verify rule modify
- security multi-admin-verify rule show
- security oauth2 commands
- security protocol commands
- security saml-sp commands
security session commands
- security session kill-cli
- security session show
- security session limit create
- security session limit delete
- security session limit modify
- security session limit show
- security session limit application create
- security session limit application delete
- security session limit application modify
- security session limit application show
- security session limit location create
- security session limit location delete
- security session limit location modify
- security session limit location show
- security session limit request create
- security session limit request delete
- security session limit request modify
- security session limit request show
- security session limit user create
- security session limit user delete
- security session limit user modify
- security session limit user show
- security session limit vserver create
- security session limit vserver delete
- security session limit vserver modify
- security session limit vserver show
- security session request-statistics show-by-application
- security session request-statistics show-by-location
- security session request-statistics show-by-request
- security session request-statistics show-by-user
- security session request-statistics show-by-vserver
- security ssh commands
- security ssl commands
- security tpm commands
- snaplock commands
snapmirror commands
- snapmirror abort
- snapmirror break
- snapmirror create
- snapmirror delete
- snapmirror flexgroup-epuuid-prefix-prepare-to-downgrade
- snapmirror initialize-ls-set
- snapmirror list-destinations
- snapmirror modify
- snapmirror promote
- snapmirror protect
- snapmirror quiesce
- snapmirror release
- snapmirror restore
- snapmirror resume
- snapmirror resync
- snapmirror set-options
- snapmirror show-history
- snapmirror show
- snapmirror update-ls-set
- snapmirror update
- snapmirror config-replication commands
- snapmirror failover commands
- snapmirror mediator commands
- snapmirror object-store commands
- snapmirror policy commands
- snapmirror snapshot-owner commands
statistics commands
- statistics show-periodic
- statistics show
- statistics start
- statistics stop
- statistics aggregate commands
- statistics cache commands
- statistics catalog commands
- statistics disk commands
- statistics lif commands
- statistics lun commands
- statistics namespace commands
- statistics nfs commands
- statistics node commands
- statistics oncrpc commands
- statistics port commands
- statistics preset commands
- statistics qtree commands
- statistics samples commands
- statistics settings commands
- statistics system commands
- statistics top commands
- statistics volume commands
- statistics vserver commands
- statistics workload commands
- statistics-v1 commands
- storage-service commands
storage commands
storage aggregate commands
- storage aggregate add-disks
- storage aggregate auto-provision
- storage aggregate create
- storage aggregate delete
- storage aggregate mirror
- storage aggregate modify
- storage aggregate offline
- storage aggregate online
- storage aggregate remove-stale-record
- storage aggregate rename
- storage aggregate restrict
- storage aggregate scrub
- storage aggregate show-auto-provision-progress
- storage aggregate show-cumulated-efficiency
- storage aggregate show-efficiency
- storage aggregate show-resync-status
- storage aggregate show-scrub-status
- storage aggregate show-space
- storage aggregate show-spare-disks
- storage aggregate show-status
- storage aggregate verify
- storage aggregate efficiency show
- storage aggregate efficiency stat
- storage aggregate efficiency cross-volume-dedupe revert-to
- storage aggregate efficiency cross-volume-dedupe show
- storage aggregate efficiency cross-volume-dedupe start
- storage aggregate efficiency cross-volume-dedupe stop
- storage aggregate encryption show-key-id
- storage aggregate inode-upgrade resume
- storage aggregate inode-upgrade show
- storage aggregate object-store attach
- storage aggregate object-store mirror
- storage aggregate object-store modify
- storage aggregate object-store show-freeing-status
- storage aggregate object-store show-resync-status
- storage aggregate object-store show-space
- storage aggregate object-store unmirror
- storage aggregate object-store config create
- storage aggregate object-store config delete
- storage aggregate object-store config modify
- storage aggregate object-store config rename
- storage aggregate object-store config show
- storage aggregate object-store profiler abort
- storage aggregate object-store profiler show
- storage aggregate object-store profiler start
- storage aggregate object-store put-rate-limit modify
- storage aggregate object-store put-rate-limit show
- storage aggregate plex delete
- storage aggregate plex offline
- storage aggregate plex online
- storage aggregate plex show
- storage aggregate reallocation quiesce
- storage aggregate reallocation restart
- storage aggregate reallocation schedule
- storage aggregate reallocation show
- storage aggregate reallocation start
- storage aggregate reallocation stop
- storage aggregate relocation show
- storage aggregate relocation start
- storage aggregate resynchronization modify
- storage aggregate resynchronization show
- storage aggregate resynchronization options modify
- storage aggregate resynchronization options show
- storage array commands
- storage automated-working-set-analyzer commands
storage disk commands
- storage disk assign
- storage disk fail
- storage disk reassign
- storage disk refresh-ownership
- storage disk remove-reservation
- storage disk removeowner
- storage disk replace
- storage disk set-foreign-lun
- storage disk set-led
- storage disk show
- storage disk unfail
- storage disk updatefirmware
- storage disk zerospares
- storage disk error show
- storage disk firmware revert
- storage disk firmware show-update-status
- storage disk firmware update
- storage disk option modify
- storage disk option show
- storage dqp commands
- storage encryption commands
- storage errors commands
storage failover commands
- storage failover check-takeover
- storage failover giveback
- storage failover modify
- storage failover show-giveback
- storage failover show-takeover
- storage failover takeover
- storage failover hwassist show
- storage failover hwassist test
- storage failover hwassist stats clear
- storage failover hwassist stats show
- storage failover internal-options show
- storage failover mailbox-disk show
- storage failover progress-table show
storage firmware commands
- storage firmware download
- storage firmware acp delete
- storage firmware acp rename
- storage firmware acp show
- storage firmware disk delete
- storage firmware disk rename
- storage firmware disk show
- storage firmware hba show
- storage firmware shelf delete
- storage firmware shelf rename
- storage firmware shelf show
- storage iscsi-initiator commands
- storage path commands
- storage pool commands
- storage port commands
- storage raid-options commands
- storage raidlm commands
storage shelf commands
- storage shelf show
- storage shelf acp configure
- storage shelf acp show
- storage shelf acp module show
- storage shelf drawer show-phy
- storage shelf drawer show-slot
- storage shelf firmware show-update-status
- storage shelf firmware update
- storage shelf location-led modify
- storage shelf location-led show
- storage shelf port show
- storage stackmon commands
storage tape commands
- storage tape offline
- storage tape online
- storage tape position
- storage tape reset
- storage tape show-errors
- storage tape show-media-changer
- storage tape show-supported-status
- storage tape show-tape-drive
- storage tape show
- storage tape trace
- storage tape alias clear
- storage tape alias set
- storage tape alias show
- storage tape config-file delete
- storage tape config-file get
- storage tape config-file show
- storage tape library config show
- storage tape library path show-by-initiator
- storage tape load-balance modify
- storage tape load-balance show
system commands
system bridge commands
- system bridge add
- system bridge modify
- system bridge refresh
- system bridge remove
- system bridge run-cli
- system bridge show
- system bridge config-dump collect
- system bridge config-dump delete
- system bridge config-dump show
- system bridge coredump collect
- system bridge coredump delete
- system bridge coredump show
- system bridge firmware update
- system bridge options modify
- system bridge options show
- system chassis commands
system configuration commands
- system configuration backup copy
- system configuration backup create
- system configuration backup delete
- system configuration backup download
- system configuration backup rename
- system configuration backup show
- system configuration backup upload
- system configuration backup settings clear-password
- system configuration backup settings modify
- system configuration backup settings set-password
- system configuration backup settings show
- system configuration recovery cluster modify
- system configuration recovery cluster recreate
- system configuration recovery cluster rejoin
- system configuration recovery cluster show
- system configuration recovery cluster sync
- system configuration recovery node restore
system controller commands
- system controller show
- system controller bootmedia show-serial-number
- system controller clus-flap-threshold show
- system controller config show-errors
- system controller config pci show-add-on-devices
- system controller config pci show-hierarchy
- system controller coredump-device show-serial-number
- system controller environment show
- system controller flash-cache show
- system controller flash-cache secure-erase run
- system controller flash-cache secure-erase show
- system controller fru show-manufacturing-info
- system controller fru led disable-all
- system controller fru led enable-all
- system controller fru led modify
- system controller fru led show
- system controller ioxm show
- system controller location-led modify
- system controller location-led show
- system controller memory dimm show
- system controller nvram-bb-threshold show
- system controller pci show
- system controller pcicerr threshold modify
- system controller pcicerr threshold show
- system controller platform-capability show
- system controller replace cancel
- system controller replace pause
- system controller replace resume
- system controller replace show-details
- system controller replace start
- system controller service-event delete
- system controller service-event show
- system controller slot module insert
- system controller slot module remove
- system controller slot module replace
- system controller slot module show
- system controller sp config show
- system controller sp upgrade show
- system feature-usage commands
- system fru-check commands
system ha commands
- system ha interconnect config show
- system ha interconnect link off
- system ha interconnect link on
- system ha interconnect ood clear-error-statistics
- system ha interconnect ood clear-performance-statistics
- system ha interconnect ood disable-optimization
- system ha interconnect ood disable-statistics
- system ha interconnect ood enable-optimization
- system ha interconnect ood enable-statistics
- system ha interconnect ood send-diagnostic-buffer
- system ha interconnect ood status show
- system ha interconnect port show
- system ha interconnect statistics clear-port-symbol-error
- system ha interconnect statistics show-scatter-gather-list
- system ha interconnect statistics performance show
- system ha interconnect status show
system health commands
- system health alert delete
- system health alert modify
- system health alert show
- system health alert definition show
- system health autosupport trigger history show
- system health config show
- system health policy definition modify
- system health policy definition show
- system health status show
- system health subsystem show
system license commands
- system license add
- system license clean-up
- system license delete
- system license show-aggregates
- system license show-serial-numbers
- system license show-status
- system license update-leases
- system license capacity show
- system license entitlement-risk show
- system license license-manager check
- system license license-manager modify
- system license license-manager show
- system license status show
- system limits commands
system node commands
- system node halt
- system node migrate-root
- system node modify
- system node reboot
- system node rename
- system node restore-backup
- system node revert-to
- system node run-console
- system node run
- system node show-discovered
- system node show
- system node autosupport invoke-core-upload
- system node autosupport invoke-diagnostic
- system node autosupport invoke-performance-archive
- system node autosupport invoke-splog
- system node autosupport modify
- system node autosupport show
- system node autosupport check show-details
- system node autosupport destinations show
- system node autosupport history cancel
- system node autosupport history retransmit
- system node autosupport history show-upload-details
- system node autosupport manifest show
- system node autosupport trigger modify
- system node autosupport trigger show
- system node coredump delete-all
- system node coredump save-all
- system node coredump show
- system node coredump status
- system node coredump trigger
- system node coredump upload
- system node coredump config modify
- system node coredump config show
- system node coredump external-device save
- system node coredump external-device show
- system node coredump reports delete
- system node coredump reports show
- system node coredump reports upload
- system node coredump segment delete-all
- system node coredump segment show
- system node environment sensors show
- system node external-cache modify
- system node external-cache show
- system node firmware download
- system node hardware nvram-encryption modify
- system node hardware nvram-encryption show
- system node hardware tape drive show
- system node hardware tape library show
- system node hardware unified-connect modify
- system node hardware unified-connect show
- system node image abort-operation
- system node image get
- system node image modify
- system node image show-update-progress
- system node image update
- system node image package delete
- system node image package show
- system node image package external-device delete
- system node image package external-device show
- system node internal-switch show
- system node internal-switch dump stat
- system node nfs usage show
- system node power on
- system node power show
- system node root-mount create
- system node root-mount delete
- system node root-mount show
- system node upgrade-revert show
- system node upgrade-revert upgrade
- system node usb-ports modify
- system node usb-ports show
- system node virtual-machine show-network-load-balancer
- system node virtual-machine disk-object-store create
- system node virtual-machine disk-object-store delete
- system node virtual-machine disk-object-store modify
- system node virtual-machine disk-object-store show
- system node virtual-machine hypervisor show
- system node virtual-machine instance show-system-disks
- system script commands
system service-processor commands
- system service-processor reboot-sp
- system service-processor show
- system service-processor api-service check
- system service-processor api-service disable-installed-certificates
- system service-processor api-service enable-installed-certificates
- system service-processor api-service modify
- system service-processor api-service regenerate-ssh-auth-key
- system service-processor api-service renew-internal-certificates
- system service-processor api-service show
- system service-processor image modify
- system service-processor image show
- system service-processor image update
- system service-processor image update-progress show
- system service-processor log show-allocations
- system service-processor network modify
- system service-processor network show
- system service-processor network auto-configuration disable
- system service-processor network auto-configuration enable
- system service-processor network auto-configuration show
- system service-processor ssh add-allowed-addresses
- system service-processor ssh remove-allowed-addresses
- system service-processor ssh show
system services commands
- system services firewall modify
- system services firewall show
- system services firewall policy clone
- system services firewall policy create
- system services firewall policy delete
- system services firewall policy modify
- system services firewall policy show
- system services manager install show
- system services manager policy add
- system services manager policy remove
- system services manager policy setstate
- system services manager policy show
- system services manager status show
- system services ndmp kill-all
- system services ndmp modify
- system services ndmp off
- system services ndmp on
- system services ndmp password
- system services ndmp probe
- system services ndmp show
- system services ndmp status
- system services ndmp log start
- system services ndmp log stop
- system services ndmp node-scope-mode off
- system services ndmp node-scope-mode on
- system services ndmp node-scope-mode status
- system services ndmp service modify
- system services ndmp service show
- system services ndmp service start
- system services ndmp service stop
- system services ndmp service terminate
- system services web modify
- system services web show
- system services web node show
- system services web ontapi modify
- system services web ontapi show
- system smtape commands
system snmp commands
- system snmp authtrap
- system snmp contact
- system snmp enable-snmpv3
- system snmp init
- system snmp location
- system snmp prepare-to-downgrade
- system snmp show
- system snmp community add
- system snmp community delete
- system snmp community show
- system snmp traphost add
- system snmp traphost delete
- system snmp traphost show
system switch commands
- system switch ethernet configure-health-monitor
- system switch ethernet create
- system switch ethernet delete
- system switch ethernet modify
- system switch ethernet show-all
- system switch ethernet fan show
- system switch ethernet interface show
- system switch ethernet log collect
- system switch ethernet log disable-collection
- system switch ethernet log enable-collection
- system switch ethernet log modify
- system switch ethernet log setup-password
- system switch ethernet log show
- system switch ethernet polling-interval modify
- system switch ethernet polling-interval show
- system switch ethernet power show
- system switch ethernet switch-count show
- system switch ethernet temperature show
- system switch ethernet threshold show
- system switch fibre-channel add
- system switch fibre-channel modify
- system switch fibre-channel refresh
- system switch fibre-channel remove
- system switch fibre-channel show
- system timeout commands
- template commands
volume commands
- volume autosize
- volume create
- volume delete
- volume expand
- volume make-vsroot
- volume modify
- volume mount
- volume offline
- volume online
- volume rehost
- volume rename
- volume restrict
- volume show-footprint
- volume show-space
- volume show
- volume size
- volume transition-prepare-to-downgrade
- volume unmount
- volume activity-tracking commands
- volume analytics commands
volume clone commands
- volume clone create
- volume clone show
- volume clone sharing-by-split show
- volume clone sharing-by-split undo show
- volume clone sharing-by-split undo start-all
- volume clone sharing-by-split undo stop
- volume clone split estimate
- volume clone split show
- volume clone split start
- volume clone split stop
- volume conversion commands
volume efficiency commands
- volume efficiency check
- volume efficiency modify
- volume efficiency off
- volume efficiency on
- volume efficiency prepare-to-downgrade
- volume efficiency promote
- volume efficiency revert-to
- volume efficiency show
- volume efficiency start
- volume efficiency stat
- volume efficiency stop
- volume efficiency undo
- volume efficiency inactive-data-compression modify
- volume efficiency inactive-data-compression show
- volume efficiency inactive-data-compression start
- volume efficiency inactive-data-compression stop
- volume efficiency inactive-data-reallocation modify
- volume efficiency inactive-data-reallocation show
- volume efficiency policy create
- volume efficiency policy delete
- volume efficiency policy modify
- volume efficiency policy show
volume encryption commands
- volume encryption conversion pause
- volume encryption conversion resume
- volume encryption conversion show
- volume encryption conversion start
- volume encryption rekey pause
- volume encryption rekey resume
- volume encryption rekey show
- volume encryption rekey start
- volume encryption secure-purge abort
- volume encryption secure-purge show
- volume encryption secure-purge start
volume file commands
- volume file compact-data
- volume file modify
- volume file privileged-delete
- volume file reservation
- volume file show-disk-usage
- volume file show-filehandle
- volume file show-inode
- volume file async-delete cancel
- volume file async-delete prepare-for-revert
- volume file async-delete show
- volume file async-delete start
- volume file async-delete client disable
- volume file async-delete client enable
- volume file async-delete client show
- volume file clone autodelete
- volume file clone create
- volume file clone show-autodelete
- volume file clone deletion add-extension
- volume file clone deletion modify
- volume file clone deletion remove-extension
- volume file clone deletion show
- volume file clone split load modify
- volume file clone split load show
- volume file fingerprint abort
- volume file fingerprint dump
- volume file fingerprint show
- volume file fingerprint start
- volume file retention show
volume flexcache commands
- volume flexcache config-refresh
- volume flexcache create
- volume flexcache delete
- volume flexcache prepare-to-downgrade
- volume flexcache show
- volume flexcache sync-properties
- volume flexcache config modify
- volume flexcache config show
- volume flexcache origin show-caches
- volume flexcache origin config modify
- volume flexcache origin config show
- volume flexcache prepopulate start
- volume flexgroup commands
- volume inode-upgrade commands
- volume move commands
- volume object-store commands
- volume qtree commands
volume quota commands
- volume quota modify
- volume quota off
- volume quota on
- volume quota report
- volume quota resize
- volume quota show
- volume quota policy copy
- volume quota policy create
- volume quota policy delete
- volume quota policy rename
- volume quota policy show
- volume quota policy rule create
- volume quota policy rule delete
- volume quota policy rule modify
- volume quota policy rule show
- volume quota policy rule count show
- volume reallocation commands
volume rebalance commands
- volume rebalance modify
- volume rebalance show
- volume rebalance start
- volume rebalance stop
- volume rebalance file-move abort
- volume rebalance file-move modify
- volume rebalance file-move show
- volume rebalance file-move start
- volume rebalance file-move statistics reset
- volume rebalance file-move statistics show
- volume recovery-queue commands
- volume schedule-style commands
- volume snaplock commands
volume snapshot commands
- volume snapshot compute-reclaimable
- volume snapshot create
- volume snapshot delete
- volume snapshot modify-snaplock-expiry-time
- volume snapshot partial-restore-file
- volume snapshot prepare-for-revert
- volume snapshot rename
- volume snapshot restore-file
- volume snapshot show-delta
- volume snapshot autodelete modify
- volume snapshot autodelete show
- volume snapshot policy add-schedule
- volume snapshot policy create
- volume snapshot policy delete
- volume snapshot policy modify-schedule
- volume snapshot policy remove-schedule
- volume snapshot policy show
vserver commands
- vserver add-aggregates
- vserver add-protocols
- vserver context
- vserver create
- vserver delete
- vserver modify
- vserver prepare-for-revert
- vserver remove-aggregates
- vserver remove-protocols
- vserver rename
- vserver restamp-msid
- vserver show-aggregates
- vserver show-protocols
- vserver show
- vserver start
- vserver stop
- vserver unlock
- vserver active-directory commands
vserver audit commands
- vserver audit create
- vserver audit delete
- vserver audit disable
- vserver audit enable
- vserver audit modify
- vserver audit prepare-to-downgrade
- vserver audit rotate-log
- vserver audit show
- vserver audit audit-log-redirect create
- vserver audit audit-log-redirect delete
- vserver audit audit-log-redirect modify
- vserver audit audit-log-redirect show
- vserver check commands
vserver cifs commands
- vserver cifs add-netbios-aliases
- vserver cifs check
- vserver cifs create
- vserver cifs delete
- vserver cifs modify
- vserver cifs nbtstat
- vserver cifs prepare-to-downgrade
- vserver cifs remove-netbios-aliases
- vserver cifs repair-modify
- vserver cifs security-encryption-required-dc-connections-prepare-to-downgrade
- vserver cifs show
- vserver cifs start
- vserver cifs stop
- vserver cifs branchcache create
- vserver cifs branchcache delete
- vserver cifs branchcache hash-create
- vserver cifs branchcache hash-flush
- vserver cifs branchcache modify
- vserver cifs branchcache show
- vserver cifs cache name-to-sid delete-all
- vserver cifs cache name-to-sid show
- vserver cifs cache settings modify
- vserver cifs cache settings show
- vserver cifs cache sid-to-name delete-all
- vserver cifs cache sid-to-name show
- vserver cifs character-mapping create
- vserver cifs character-mapping delete
- vserver cifs character-mapping modify
- vserver cifs character-mapping show
- vserver cifs connection show
- vserver cifs domain discovered-servers reset-servers
- vserver cifs domain discovered-servers show
- vserver cifs domain discovered-servers discovery-mode modify
- vserver cifs domain discovered-servers discovery-mode show
- vserver cifs domain name-mapping-search add
- vserver cifs domain name-mapping-search modify
- vserver cifs domain name-mapping-search remove
- vserver cifs domain name-mapping-search show
- vserver cifs domain password change
- vserver cifs domain password reset
- vserver cifs domain password schedule modify
- vserver cifs domain password schedule show
- vserver cifs domain preferred-dc add
- vserver cifs domain preferred-dc check
- vserver cifs domain preferred-dc remove
- vserver cifs domain preferred-dc show
- vserver cifs domain trusts rediscover
- vserver cifs domain trusts show
- vserver cifs group-policy modify
- vserver cifs group-policy show-applied
- vserver cifs group-policy show-defined
- vserver cifs group-policy update
- vserver cifs group-policy central-access-policy show-applied
- vserver cifs group-policy central-access-policy show-defined
- vserver cifs group-policy central-access-rule show-applied
- vserver cifs group-policy central-access-rule show-defined
- vserver cifs group-policy restricted-group show-applied
- vserver cifs group-policy restricted-group show-defined
- vserver cifs home-directory modify
- vserver cifs home-directory show-user
- vserver cifs home-directory search-path add
- vserver cifs home-directory search-path remove
- vserver cifs home-directory search-path reorder
- vserver cifs home-directory search-path show
- vserver cifs options modify
- vserver cifs options show
- vserver cifs security modify
- vserver cifs security show
- vserver cifs session close
- vserver cifs session show
- vserver cifs session file close
- vserver cifs session file show
- vserver cifs share create
- vserver cifs share delete
- vserver cifs share modify
- vserver cifs share show
- vserver cifs share access-control create
- vserver cifs share access-control delete
- vserver cifs share access-control modify
- vserver cifs share access-control show
- vserver cifs share properties add
- vserver cifs share properties remove
- vserver cifs share properties show
- vserver cifs superuser create
- vserver cifs superuser delete
- vserver cifs superuser show
- vserver cifs symlink create
- vserver cifs symlink delete
- vserver cifs symlink modify
- vserver cifs symlink show
- vserver cifs users-and-groups remove-stale-records
- vserver cifs users-and-groups update-names
- vserver cifs users-and-groups local-group add-members
- vserver cifs users-and-groups local-group create
- vserver cifs users-and-groups local-group delete
- vserver cifs users-and-groups local-group modify
- vserver cifs users-and-groups local-group remove-members
- vserver cifs users-and-groups local-group rename
- vserver cifs users-and-groups local-group show-members
- vserver cifs users-and-groups local-user create
- vserver cifs users-and-groups local-user delete
- vserver cifs users-and-groups local-user modify
- vserver cifs users-and-groups local-user rename
- vserver cifs users-and-groups local-user set-password
- vserver cifs users-and-groups local-user show-membership
- vserver cifs users-and-groups privilege add-privilege
- vserver cifs users-and-groups privilege remove-privilege
- vserver cifs users-and-groups privilege reset-privilege
- vserver cifs users-and-groups privilege show
- vserver config-replication commands
vserver consistency-group commands
- vserver consistency-group attach
- vserver consistency-group create
- vserver consistency-group delete
- vserver consistency-group demote
- vserver consistency-group detach
- vserver consistency-group modify
- vserver consistency-group promote
- vserver consistency-group show
- vserver consistency-group clone create
- vserver consistency-group lun show
- vserver consistency-group namespace show
- vserver consistency-group snapshot commit
- vserver consistency-group snapshot create
- vserver consistency-group snapshot delete
- vserver consistency-group snapshot restore
- vserver consistency-group snapshot show
- vserver consistency-group snapshot start
- vserver consistency-group volume add
- vserver consistency-group volume create
- vserver consistency-group volume reassign
- vserver consistency-group volume remove
- vserver consistency-group volume show
vserver export-policy commands
- vserver export-policy check-access
- vserver export-policy copy
- vserver export-policy create
- vserver export-policy delete
- vserver export-policy rename
- vserver export-policy show
- vserver export-policy access-cache flush
- vserver export-policy access-cache show-negative
- vserver export-policy access-cache show-rules
- vserver export-policy access-cache config modify-all-vservers
- vserver export-policy access-cache config show-all-vservers
- vserver export-policy cache flush
- vserver export-policy config-checker show
- vserver export-policy config-checker start
- vserver export-policy config-checker stop
- vserver export-policy config-checker rule delete
- vserver export-policy config-checker rule show
- vserver export-policy netgroup check-membership
- vserver export-policy netgroup cache show
- vserver export-policy netgroup queue show
- vserver export-policy rule add-clientmatches
- vserver export-policy rule create
- vserver export-policy rule delete
- vserver export-policy rule modify
- vserver export-policy rule remove-clientmatches
- vserver export-policy rule setindex
- vserver export-policy rule show
vserver fcp commands
- vserver fcp create
- vserver fcp delete
- vserver fcp modify
- vserver fcp show
- vserver fcp start
- vserver fcp stop
- vserver fcp initiator show
- vserver fcp interface show
- vserver fcp nameserver show
- vserver fcp ping-igroup show
- vserver fcp ping-initiator show
- vserver fcp portname set
- vserver fcp portname show
- vserver fcp topology show
- vserver fcp wwn blacklist show
- vserver fcp wwpn-alias remove
- vserver fcp wwpn-alias set
- vserver fcp wwpn-alias show
vserver fpolicy commands
- vserver fpolicy disable
- vserver fpolicy enable
- vserver fpolicy engine-connect
- vserver fpolicy engine-disconnect
- vserver fpolicy show-enabled
- vserver fpolicy show-engine
- vserver fpolicy show-passthrough-read-connection
- vserver fpolicy persistent-store create
- vserver fpolicy persistent-store delete
- vserver fpolicy persistent-store modify
- vserver fpolicy persistent-store show
- vserver fpolicy policy create
- vserver fpolicy policy delete
- vserver fpolicy policy modify
- vserver fpolicy policy show
- vserver fpolicy policy event create
- vserver fpolicy policy event delete
- vserver fpolicy policy event modify
- vserver fpolicy policy event show
- vserver fpolicy policy external-engine create
- vserver fpolicy policy external-engine delete
- vserver fpolicy policy external-engine modify
- vserver fpolicy policy external-engine show
- vserver fpolicy policy scope create
- vserver fpolicy policy scope delete
- vserver fpolicy policy scope modify
- vserver fpolicy policy scope show
- vserver http-proxy commands
vserver iscsi commands
- vserver iscsi create
- vserver iscsi delete
- vserver iscsi modify
- vserver iscsi show
- vserver iscsi start
- vserver iscsi stop
- vserver iscsi command show
- vserver iscsi connection show
- vserver iscsi connection shutdown
- vserver iscsi initiator show
- vserver iscsi interface disable
- vserver iscsi interface enable
- vserver iscsi interface modify
- vserver iscsi interface show
- vserver iscsi interface accesslist add
- vserver iscsi interface accesslist remove
- vserver iscsi interface accesslist show
- vserver iscsi isns create
- vserver iscsi isns delete
- vserver iscsi isns modify
- vserver iscsi isns show
- vserver iscsi isns start
- vserver iscsi isns stop
- vserver iscsi isns update
- vserver iscsi security add-initator-address-ranges
- vserver iscsi security create
- vserver iscsi security default
- vserver iscsi security delete
- vserver iscsi security modify
- vserver iscsi security prepare-to-downgrade
- vserver iscsi security remove-initator-address-ranges
- vserver iscsi security show
- vserver iscsi session show
- vserver iscsi session shutdown
- vserver iscsi session parameter show
- vserver locks commands
- vserver migrate commands
- vserver name-mapping commands
vserver nfs commands
- vserver nfs create
- vserver nfs delete
- vserver nfs modify
- vserver nfs off
- vserver nfs on
- vserver nfs prepare-for-v3-ms-dos-client-downgrade
- vserver nfs prepare-to-downgrade
- vserver nfs show
- vserver nfs start
- vserver nfs status
- vserver nfs stop
- vserver nfs connected-clients show
- vserver nfs credentials count
- vserver nfs credentials flush
- vserver nfs credentials show
- vserver nfs kerberos interface disable
- vserver nfs kerberos interface enable
- vserver nfs kerberos interface modify
- vserver nfs kerberos interface show
- vserver nfs kerberos realm create
- vserver nfs kerberos realm delete
- vserver nfs kerberos realm modify
- vserver nfs kerberos realm show
- vserver nfs pnfs devices create
- vserver nfs pnfs devices delete
- vserver nfs pnfs devices show
- vserver nfs pnfs devices cache show
- vserver nfs pnfs devices mappings show
- vserver nfs storepool show
- vserver nfs storepool blocked-client flush
- vserver nfs storepool blocked-client show
- vserver nfs storepool config modify
- vserver nfs storepool config show
vserver nvme commands
- vserver nvme create
- vserver nvme delete
- vserver nvme modify
- vserver nvme show-discovery-controller
- vserver nvme show-host-priority
- vserver nvme show-interface
- vserver nvme show
- vserver nvme feature show
- vserver nvme namespace convert-from-lun
- vserver nvme namespace create
- vserver nvme namespace delete
- vserver nvme namespace modify
- vserver nvme namespace show
- vserver nvme subsystem create
- vserver nvme subsystem delete
- vserver nvme subsystem modify
- vserver nvme subsystem show
- vserver nvme subsystem controller show
- vserver nvme subsystem host add
- vserver nvme subsystem host remove
- vserver nvme subsystem host show
- vserver nvme subsystem map add
- vserver nvme subsystem map remove
- vserver nvme subsystem map show
vserver object-store-server commands
- vserver object-store-server create
- vserver object-store-server delete
- vserver object-store-server modify
- vserver object-store-server show
- vserver object-store-server audit create
- vserver object-store-server audit delete
- vserver object-store-server audit disable
- vserver object-store-server audit enable
- vserver object-store-server audit modify
- vserver object-store-server audit rotate-log
- vserver object-store-server audit show
- vserver object-store-server audit event-selector create
- vserver object-store-server audit event-selector delete
- vserver object-store-server audit event-selector modify
- vserver object-store-server audit event-selector show
- vserver object-store-server bucket create
- vserver object-store-server bucket delete
- vserver object-store-server bucket evict-remote-cached-objects
- vserver object-store-server bucket modify
- vserver object-store-server bucket show-nas-bucket
- vserver object-store-server bucket lifecycle-management-rule create
- vserver object-store-server bucket lifecycle-management-rule delete
- vserver object-store-server bucket lifecycle-management-rule modify
- vserver object-store-server bucket lifecycle-management-rule show
- vserver object-store-server bucket policy-statement-condition create
- vserver object-store-server bucket policy-statement-condition delete
- vserver object-store-server bucket policy-statement-condition modify
- vserver object-store-server bucket policy-statement-condition show
- vserver object-store-server bucket policy statement create
- vserver object-store-server bucket policy statement delete
- vserver object-store-server bucket policy statement modify
- vserver object-store-server bucket policy statement show
- vserver object-store-server group create
- vserver object-store-server group delete
- vserver object-store-server group modify
- vserver object-store-server group show
- vserver object-store-server policy create
- vserver object-store-server policy delete
- vserver object-store-server policy modify
- vserver object-store-server policy show
- vserver object-store-server policy statement create
- vserver object-store-server policy statement delete
- vserver object-store-server policy statement modify
- vserver object-store-server policy statement show
- vserver object-store-server user create
- vserver object-store-server user delete-keys
- vserver object-store-server user modify
- vserver object-store-server user regenerate-keys
- vserver object-store-server user show
vserver peer commands
- vserver peer accept
- vserver peer create
- vserver peer delete
- vserver peer modify-local-name
- vserver peer reject
- vserver peer repair-peer-name
- vserver peer resume
- vserver peer show-all
- vserver peer show
- vserver peer suspend
- vserver peer permission create
- vserver peer permission delete
- vserver peer permission modify
- vserver peer permission show
- vserver peer transition create
- vserver peer transition delete
- vserver peer transition modify
- vserver peer transition show
- vserver san commands
vserver security commands
- vserver security file-directory apply
- vserver security file-directory remove-slag
- vserver security file-directory show-effective-permissions
- vserver security file-directory job show
- vserver security file-directory ntfs create
- vserver security file-directory ntfs delete
- vserver security file-directory ntfs modify
- vserver security file-directory ntfs show
- vserver security file-directory ntfs dacl add
- vserver security file-directory ntfs dacl modify
- vserver security file-directory ntfs dacl remove
- vserver security file-directory ntfs dacl show
- vserver security file-directory ntfs sacl add
- vserver security file-directory ntfs sacl modify
- vserver security file-directory ntfs sacl remove
- vserver security file-directory ntfs sacl show
- vserver security file-directory policy create
- vserver security file-directory policy delete
- vserver security file-directory policy show
- vserver security file-directory policy task add
- vserver security file-directory policy task modify
- vserver security file-directory policy task remove
- vserver security file-directory policy task show
- vserver security trace filter create
- vserver security trace filter delete
- vserver security trace filter modify
- vserver security trace filter show
- vserver security trace trace-result delete
- vserver security trace trace-result show
vserver services commands
- vserver services access-check authentication get-claim-name
- vserver services access-check authentication get-dc-info
- vserver services access-check authentication login-cifs
- vserver services access-check authentication ontap-admin-ldap-fastbind
- vserver services access-check authentication ontap-admin-login-cifs
- vserver services access-check authentication show-creds
- vserver services access-check authentication show-ontap-admin-unix-creds
- vserver services access-check authentication sid-to-uid
- vserver services access-check authentication sid-to-unix-name
- vserver services access-check authentication translate
- vserver services access-check authentication uid-to-sid
- vserver services access-check dns forward-lookup
- vserver services access-check dns srv-lookup
- vserver services access-check name-mapping show
- vserver services access-check server-discovery reset
- vserver services access-check server-discovery show-host
- vserver services access-check server-discovery show-site
- vserver services access-check server-discovery test
- vserver services name-service cache group-membership delete-all
- vserver services name-service cache group-membership show
- vserver services name-service cache group-membership settings modify
- vserver services name-service cache group-membership settings show
- vserver services name-service cache hosts forward-lookup delete-all
- vserver services name-service cache hosts forward-lookup show
- vserver services name-service cache hosts reverse-lookup delete-all
- vserver services name-service cache hosts reverse-lookup show
- vserver services name-service cache hosts settings modify
- vserver services name-service cache hosts settings show
- vserver services name-service cache netgroups ip-to-netgroup del
