ONTAP commands
security login totp modify
Modify a TOTP status
The security login totp modify command modifies the TOTP status. Only admin can modify the TOTP status and it requires that you enter a user name and enabled
-vserver <vserver name> - Vserver
This parameter optionally specifies the Vserver of the user for whom you are modifying the TOTP status or comment.
-username <text> - Username
This parameter specifies the name of the user for whom you are modifying the TOTP status.
[-enabled {true|false}] - TOTP Status
This parameter specifies the TOTP status of the user for whom you are modifying.
[-comment <text>] - Comment
This optionally specifies comment text for the TOTP key. Note that comment text should be enclosed in quotation marks.
The following command disable the TOTP for the user named tsmith for Vserver vs1.
cluster1::> security login totp modify -vserver vs1 -username tsmith -enabled false
