job private show-completed
Display a list of completed jobs
The job private show-completed command displays information about completed private jobs. Private jobs are affiliated with a specific node and do not use any cluster facilities, such as the replicated database.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node (privilege: advanced)
Use this parameter to display information only about completed jobs that are associated with the node you specify.
[-id <integer>] - Job ID (privilege: advanced)
Use this parameter to display information only about completed jobs that have the ID you specify.
[-vserver <vserver name>] - Owning Vserver (privilege: advanced)
Use this parameter to display only completed jobs that are owned by the Vserver you specify.
[-name <text>] - Name (privilege: advanced)
Use this parameter to display information only about completed jobs that have the name you specify.
[-description <text>] - Description (privilege: advanced)
Use this parameter to display information only about completed jobs that have the description you specify.
[-priority {Low|Medium|High|Exclusive}] - Priority (privilege: advanced)
Use this parameter to display information only about completed jobs that have the priority you specify.
[-schedule <job_schedule>] - Schedule (privilege: advanced)
Use this parameter to display information only about completed jobs that have the schedule you specify.
[-queuetime <MM/DD HH:MM:SS>] - Queue Time (privilege: advanced)
Use this parameter to display information only about completed jobs that have the queue time you specify.
[-starttime <MM/DD HH:MM:SS>] - Start Time (privilege: advanced)
Use this parameter to display information only about completed jobs that have the start time you specify.
[-endtime <MM/DD HH:MM:SS>] - End Time (privilege: advanced)
Use this parameter to display information only about completed jobs that have the end time you specify.
[-dropdeadtime <MM/DD HH:MM:SS>] - Drop-dead Time (privilege: advanced)
Use this parameter to display information only about completed jobs that have the final timeout time you specify.
[-restarted {true|false}] - Restarted? (privilege: advanced)
Use this parameter to display information only about completed jobs that have the restart value you specify.
[-state {Initial|Queued|Running|Waiting|Pausing|Paused|Quitting|Success|Failure|Reschedule|Error|Quit|Dead|Unknown|Restart|Dormant}] - State (privilege: advanced)
Use this parameter to display information only about completed jobs that have the job state you specify.
[-code <integer>] - Status Code (privilege: advanced)
Use this parameter to display information only about completed jobs that have the status code you specify.
[-completion <text>] - Completion String (privilege: advanced)
Use this parameter to display information only about completed jobs that have the completion text you specify.
[-jobtype <text>] - Job Type (privilege: advanced)
Use this parameter to display information only about completed jobs that have the job type you specify.
[-category <text>] - Job Category (privilege: advanced)
Use this parameter to display information only about completed jobs that have the job category you specify.
[-uuid <UUID>] - UUID (privilege: advanced)
Use this parameter to display information only about completed jobs that have the UUID you specify.
[-username <text>] - User Name (privilege: advanced)
Use this parameter to display information only about completed jobs that are associated with the user you specify.
The following example shows how to display information about all completed private jobs on the node named node1 :
cluster1::*> job private show-completed -node node1
Node: node1
                      Owning
Job ID Name           Vserver    End Time       Code     Completion String
1      sync task      node1      02/17 15:03:23 0
2      load_balancing node1      02/17 16:29:28 0        DONE_VIF_STATS
3      snap-hourly    node1      02/17 16:05:00 0
4      snap-daily     node1      02/17 00:10:00 0
5      snap-weekly    node1      02/13 00:15:00 0
8      Cross-Cluster Manager node1 02/17 16:27:27 0      complete
9      reconcile service policy node1 02/17 15:03:12 0
7 entries were displayed.
