The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
event filter update-access-control-role
PDF of this doc site
Creating your file...
Your file is ready
Update access-control-role of an event filter
The event filter update-access-control-role
command is used to update the 'access-control-role' field of an existing event filter.
-filter-name <text>
- Filter Name (privilege: advanced)-
Specify the event filter name with this mandatory parameter.
-new-access-control-role <text>
- New Access Control Role (privilege: advanced)-
Specify the new access control role with this mandatory parameter.
This example shows how to update the access control role of an event filter named filter1:
cluster1::*> event filter show-summary Filter Name Rule Count System-Defined Access Control Role ------------------ ---------- -------------- ------------------- default-trap-events 4 true - filter1 2 false - important-events 3 true - no-info-debug-events 2 true - 4 entries were displayed. cluster1::*> event filter update-access-control-role -filter-name filter1 -new-access-control-role new_role cluster1::*> event filter show-summary Filter Name Rule Count System-Defined Access Control Role ------------------ ---------- -------------- ------------------- default-trap-events 4 true - filter1 2 false new_role important-events 3 true - no-info-debug-events 2 true - 4 entries were displayed.
