event filter update-access-control-role
Update access-control-role of an event filter
The event filter update-access-control-role command is used to update the 'access-control-role' field of an existing event filter.
-filter-name <text>- Filter Name (privilege: advanced)-
Specify the event filter name with this mandatory parameter.
-new-access-control-role <text>- New Access Control Role (privilege: advanced)-
Specify the new access control role with this mandatory parameter.
This example shows how to update the access control role of an event filter named filter1:
cluster1::*> event filter show-summary
Filter Name Rule Count System-Defined Access Control Role
default-trap-events
4 true -
filter1 2 false -
important-events 3 true -
no-info-debug-events
2 true -
4 entries were displayed.
cluster1::*> event filter update-access-control-role -filter-name filter1 -new-access-control-role new_role
default-trap-events
4 true -
filter1 2 false new_role
2 true -
