security oauth2 client delete
Delete OAuth 2.0 Provider
The security oauth2 client delete command is used to remove an OAuth 2.0 Provider configuration.
-config-name <text>- Configuration Entry Name-
This is the OAuth 2.0 configuration entry name.
The following example removes the OAuth 2.0 Provider configuration named auth1:
cluster1::> security oauth2 client delete -config-name auth1
The following example removes all OAuth2.0 Provider configurations:
cluster1::> security oauth2 client delete -config-name *
