The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver cifs domain discovered-servers reset-servers
PDF of this doc site
Creating your file...
Your file is ready
Reset and rediscover servers for a Vserver
The vserver cifs domain discovered-servers reset-servers
command discards information the storage system has stored about domain controllers, LDAP, and NIS servers. After that, it begins the discovery process to reacquire current information about external servers.
-vserver <vserver name>
- Vserver-
This parameter specifies the name of the Vserver.
The following is an example use of this command. It produces no output.
cluster1::> vserver cifs domain discovered-servers reset-servers cluster1::>
