vserver cifs domain discovered-servers reset-servers
Reset and rediscover servers for a Vserver
The vserver cifs domain discovered-servers reset-servers command discards information the storage system has stored about domain controllers, LDAP, and NIS servers. After that, it begins the discovery process to reacquire current information about external servers.
-vserver <vserver name> - Vserver
This parameter specifies the name of the Vserver.
The following is an example use of this command. It produces no output.
cluster1::> vserver cifs domain discovered-servers reset-servers
cluster1::>
