vserver consistency-group snapshot delete
Delete an existing consistency group Snapshot Copy
The vserver consistency-group snapshot delete command deletes a Snapshot copy of a specified consistency group.
-vserver <Vserver Name>- Vserver Name-
This parameter specifies the Vserver that contains the consistency group on which the snapshot is to be deleted.
-consistency-group <text>- Consistency Group Name-
This parameter specifies the consistency group where a Snapshot copy is to be deleted.
-parent-consistency-group <text>- Parent Consistency Group Name-
This parameter specifies the parent consistency group where a Snapshot copy is to be deleted.
-snapshot <snapshot name>- Snapshot Copy Name-
This parameter specifies the name of the Snapshot copy that is to be deleted.
The following example deletes a Snapshot copy named snap1 on a child consistency group named cg1 in parent consistency group parentCg on a Vserver named vs0.
cluster1::> vserver consistency-group snapshot delete -vserver vs0 -consistency-group cg1 -parent-consistency-group parentCg -snapshot snap1
(vserver consistency-group snapshot delete)
Warning: Deleting a Snapshot copy permanently removes data that is stored only in that Snapshot copy. Are you sure you want to delete Snapshot copy
"snap1" for consistency group "parentCG" in Vserver "vs0" ? {y|n}: y
