      vserver services access-check authentication ontap-admin-ldap-fastbind
Authenticate Data ONTAP admin CIFS user
The vserver services access-check authentication ontap-admin-ldap-fastbind command authenticates the Data ONTAP administrator's user through the specified node using LDAP fast bind mechanism. It uses the LDAP client configuration of the specified Vserver.
- [-node {<nodename>|local}]- Node (privilege: advanced)
The name of the node on which the command is executed.
- -vserver <vserver>- Vserver (privilege: advanced)
The name of the Vserver with LDAP configuration.
- -user <text>- User Name (privilege: advanced)
The name of the user present in LDAP server.
This example authenticates the Data ONTAP administrator user "administrator" through node "node2" using the LDAP configuration of Vserver "vs1".
cluster1::vserver services access-check*> authentication ontap-admin-ldap-fastbind -vserver vs1 -user administrator -node node2 Enter the password: Authentication Succeeded.
 PDFs
PDFs
