security login duo group create
Add a Duo Group Configuration
The security login duo group create creates the groups that need to included in Duo authentication.
-vserver <vserver name>- Vserver-
This parameter optionally specifies the Vserver of the Duo group that is being created.
-group-name <text>- Group Name-
This parameter specifies the name of the group that will be part of Duo authentication.
[-excluded-users <text>,…]- List of Excluded Users-
This parameter optionally specifies the list of users that will be excluded from Duo authentication.
[-comment <text>]- Comment-
This parameter optionally specifies the comments
The following command creates a group "test" on vserver "VS1" and exclude the user tsmith from Duo authentication.
cluster1::> security login duo group create -vserver vs1 -group-name vs1 -exclude-users tsmith
