The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
metrocluster configuration-settings calibration measure
PDF of this doc site
Creating your file...
Your file is ready
Measure latency and bandwith values
The metrocluster configuration-settings calibration measure
command measures the bandwidth and latency between local and remote nodes in a MetroCluster over IP configuration.
This command should not be run when the MetroCluster configuration is under a heavy load. Bandwidth measurements will attempt to fully saturate network connections to the remote cluster and may disrupt the quality of service.
The following example shows the output for the calibration measure command in MetroCluster over IP configurations:
clusA::*> metrocluster configuration-settings calibration measure Warning: This operation will attempt to fully saturate the network connection to the remote cluster for measuring bandwidth. This may disrupt performance and should not be run when MetroCluster is under heavy load. Do you want to continue? {y|n}: y Measuring latency and bandwidth between node "A1" (10.140.113.214) and node "B1" (10.140.113.26) over port "e0f". Measuring latency and bandwidth between node "A1" (10.140.113.215) and node "B1" (10.140.113.27) over port "e0g". Measuring latency and bandwidth between node "A2" (10.140.113.216) and node "B2" (10.140.113.25) over port "e0f". Measuring latency and bandwidth between node "A2" (10.140.113.217) and node "B2" (10.140.113.28) over port "e0g". Measurements complete. Use the "metrocluster configuration-settings calibration show" command to display the results.
