ONTAP commands
security multi-admin-verify show
Display multi-admin-verify configuration
The security multi-admin-verify show command displays the object store that contains the global setting values of the multi-admin-verify feature.
  • Is Enabled: Displays the current state of the feature. This feature is, by default, disabled and the value is set to false.
  • Required Approvers: Displays the required number of approvers to approve the ONTAP execution request. This is inherited by the rule if required-approvers is not provided for the rule. The default and minimum number of required approvers is 1.
  • Approval Expiry: Displays the amount of time that the approvers have after a new execution request is submitted to approve or disapprove the request before the request expires.
  • Execution Expiry: Displays the amount of time that the authorized users have after a request is approved to execute the requested operation before the request expires.
  • Approval Groups: Displays the list of global approval groups. This will be in effect if the approval groups is not specified for a multi-admin-verify rule.
The following example displays typical global settings information:
cluster1::> security multi-admin-verify show
Is      Required  Execution Approval Approval
    Enabled Approvers Expiry    Expiry   Groups
    false   1         1h        1h       group1, group2
