event filter copy
Copy an event filter
The event filter copy command copies an existing filter to a new filter. The new filter will be created with rules from the source filter. For more information, see the event filter create command.
-filter-name <text>- Filter Name-
Use this mandatory parameter to specify the name of the event filter to copy.
-new-filter-name <text>- New Event Filter Name-
Use this mandatory parameter to specify the name of the new event filter to create and copy the rules.
The following example copies an existing event filter named emer-wafl-events to a new filter named filter1:
cluster1::> event filter show
Filter Rule Rule SNMP Trap
Name Posn Type Message Name Severity Type Parameters
default-trap-events
1 include * EMERGENCY, ALERT
2 include * * Standard, Built-in
3 exclude * * * *=*
emer-wafl-events
1 include wafl.* EMERGENCY * *=*
2 exclude * * * *=*
important-events
2 include callhome.* ERROR * *=*
3 exclude * * * *=*
no-info-debug-events
1 include * EMERGENCY, ALERT, ERROR, NOTICE
2 exclude * * * *=*
10 entries were displayed.
cluster1::> event filter copy -filter-name emer-wafl-events -new-filter-name filter1
default-trap-events
3 exclude * * * *=*
emer-wafl-events
2 exclude * * * *=*
filter1
2 exclude * * * *=*
important-events
3 exclude * * * *=*
2 exclude * * * *=*
12 entries were displayed.
