ONTAP commands
storage aggregate online
Online an aggregate
The storage aggregate online command brings an aggregate online if the aggregate is in offline or restricted state. If an aggregate is in an inconsistent state, it must be brought to a consistent state before it can be brought online. If you have an aggregate that is in an inconsistent state, contact technical support.
-aggregate <aggregate name> - Aggregate
The name of the aggregate to be brought online.
The following example brings an aggregate named aggr1 online:
cluster1::> storage aggregate online -aggregate aggr1
