volume analytics initialization show
Display file system analytics information
The volume analytics initialization show command displays the file system analytics initialization information for a volume. By default, the command displays the following information:
Vserver name
Volume name
File system analytics initialization state
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver Name-
If this parameter is specified, the command displays information only about the volumes in vservers that match the specified value for
-vserver [-volume <volume name>]- Volume Name-
If this parameter is specified, the command displays information only about the volumes that match the specified value for
-volume [-state <Analytics Initialization State>]- State-
If this parameter is specified, the command displays information only about the volume or volumes that have the specified file system analytics initialization state.
The following example displays the file system analytics initialization information on a volume named "vol1" in Vserver "vs1":
cluster::*> volume analytics initialization show -vserver vs1 -volume vol1
Vserver Name: vs1
Volume Name: vol1
State: Running
