volume analytics initialization show
Display file system analytics information
The volume analytics initialization show
command displays the file system analytics initialization information for a volume. By default, the command displays the following information:
Vserver name
Volume name
File system analytics initialization state
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver Name-
If this parameter is specified, the command displays information only about the volumes in vservers that match the specified value for
-vserver
[-volume <volume name>]
- Volume Name-
If this parameter is specified, the command displays information only about the volumes that match the specified value for
-volume
[-state <Analytics Initialization State>]
- State-
If this parameter is specified, the command displays information only about the volume or volumes that have the specified file system analytics initialization state.
The following example displays the file system analytics initialization information on a volume named "vol1" in Vserver "vs1":
cluster::*> volume analytics initialization show -vserver vs1 -volume vol1 Vserver Name: vs1 Volume Name: vol1 State: Running
