The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
security multi-admin-verify request approve
PDF of this doc site
Creating your file...
Your file is ready
Approve a request
The security multi-admin-verify request approve
command approves the specified request.
-index <integer>
- Request Index-
This allows the user to specify the index of the request to be approved.
[-execute-on-approval {true|false}]
- Execute Command On Final Approval-
If set to
true
, the operation will automatically execute on final approval.
The following example approves the request with index 1:
cluster1::> security multi-admin-verify request approve -index 1
