security multi-admin-verify request approve
Approve a request
The security multi-admin-verify request approve command approves the specified request. Cluster peering commands might require remote approvals.
-index <integer>- Request Index-
This allows the user to specify the index of the request to be approved.
[-execute-on-approval {true|false}]- Execute Command On Final Approval-
If set to
true, the operation will automatically execute on final approval.
The following example approves the request with index 1:
cluster1::> security multi-admin-verify request approve -index 1
