system controller coredump-device show
Display the coredump device health status
The system controller coredump-device show command displays details of the coredump devices present in all the nodes in a cluster. This command is only applicable to AFF A700 systems. By default, the command displays the following information about the coredump device:
Node name
Display name
Vendor ID
Device ID
Memory size
Device state
Health monitor status
To display more details, use the -instance parameter.
[-fields <fieldname>,…] -
Selects the fields that you specify.
[-instance ]} -
Displays detailed information for the coredump device.
[-node {<nodename>|local}]- Node-
Selects the coredump device that is present on the specified node.
[-serial-num <text>]- Serial Number-
Selects the coredump device with the specified serial number.
[-vendor-id <Hex Integer>]- Vendor ID-
Selects the coredump device with the specified vendor ID.
[-device-id <Hex Integer>]- Device ID-
Selects the coredump device with the specified device ID.
[-display-name <text>]- Display Name-
Selects the coredump device with the specified display name.
[-unique-name <text>]- Unique Name-
Selects the coredump device with the specified unique name.
[-monitor {node-connect|system-connect|system|controller|chassis|cluster-switch|example|ethernet-switch}]- Health Monitor Name-
Selects the coredump device with the specified health monitor.
[-health-status {present|not-present}]- Health Status-
Selects the coredump device with the specified health status.
[-device-state {good|warn|bad}]- Device State-
Selects the coredump device with the specified device state.
[-size <integer>]- Max Memory Size (GB)-
Selects the coredump device with the specified memory size.
[-health {ok|ok-with-suppressed|degraded|unreachable|unknown}]- Status-
Selects the coredump device with the specified health monitor status.
[-shelf-status {present|not-present}]- Shelf Connected Status-
Selects the coredump device with the specific shelf connected status.
The following example displays the information of the coredump devices present in all the nodes in a cluster:
cluster1::> system controller coredump-device show
Size Device
Node FRU/Display Name Vendor ID Device ID (GB) State Status
cluster1-01
Coredump/X9170A 1b85 4018 1024 good ok
cluster1-02
2 entries were displayed.
The example below displays the detailed information about the coredump device present in a node.
cluster1::> system controller coredump-device show -instance -node cluster1-01
Node: cluster1-01
Serial Number: A22P5061550000644
Vendor ID: 1b85
Device ID: 4018
Display Name: Coredump/X9170A
Unique Name: 0X91701190020741OCZ000Z63000001T0003500
Health Monitor Name: controller
Health Status: present
Device State: good
Max Memory Size (GB): 1024
Status: ok
Shelf Connected Status: present
