vserver fcp portname show
- PDF of this doc site
Creating your file...
Display WWPN for FCP logical interfaces
This command displays a list of World Wide Port Names (WWPN) that are used by the FCP logical interfaces.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver-
Use this parameter to display a list of FCP logical interfaces and their WWPNs that match the Vserver name you specify.
[-lif <lif-name>]
- Logical Interface-
Use this parameter to display a list of FCP logical interfaces and their WWPNs that match the logical interface that you specify. You can use wildcards in the logical interface to display a specific group of logical interfaces.
[-wwpn <text>]
- WWPN-
Use this parameter to display a list of FCP logical interfaces and their WWPNs that match the WWPN that you specify. You can use wildcards in the WWPN to display a specific group of WWPNs.
cluster1::> vserver fcp portname show Logical Vserver Interface WWPN --------- -------------- ------------------------- vs_a vs_a.fcp 2f:a2:00:a0:98:0b:56:13 vs_io1 vs_io1.fcp 2f:9e:00:a0:98:0b:56:13 vs_2 lif2 2f:a3:00:a0:98:0b:56:13 vs_2 lif3 2f:a4:00:a0:98:0b:56:13 vs_2 lif4 2f:a5:00:a0:98:0b:56:13 vs_2 lif5 2f:a6:00:a0:98:0b:56:13 vs_2 vs_2.fcp 2f:9a:00:a0:98:0b:56:13 vs1 vs1.fcp 2f:9d:00:a0:98:0b:56:13 vs1 vs1.fcp2 2f:97:00:a0:98:0b:56:13
Displays the WWPNs for each FCP logical interface for all the Vservers in a cluster.
