ONTAP commands
vserver fcp portname show
Display WWPN for FCP logical interfaces
This command displays a list of World Wide Port Names (WWPN) that are used by the FCP logical interfaces.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver
Use this parameter to display a list of FCP logical interfaces and their WWPNs that match the Vserver name you specify.
[-lif <lif-name>] - Logical Interface
Use this parameter to display a list of FCP logical interfaces and their WWPNs that match the logical interface that you specify. You can use wildcards in the logical interface to display a specific group of logical interfaces.
[-wwpn <text>] - WWPN
Use this parameter to display a list of FCP logical interfaces and their WWPNs that match the WWPN that you specify. You can use wildcards in the WWPN to display a specific group of WWPNs.
cluster1::> vserver fcp portname show
           Logical
Vserver    Interface      WWPN
vs_a       vs_a.fcp       2f:a2:00:a0:98:0b:56:13
vs_io1     vs_io1.fcp     2f:9e:00:a0:98:0b:56:13
vs_2       lif2           2f:a3:00:a0:98:0b:56:13
vs_2       lif3           2f:a4:00:a0:98:0b:56:13
vs_2       lif4           2f:a5:00:a0:98:0b:56:13
vs_2       lif5           2f:a6:00:a0:98:0b:56:13
vs_2       vs_2.fcp       2f:9a:00:a0:98:0b:56:13
vs1        vs1.fcp        2f:9d:00:a0:98:0b:56:13
vs1        vs1.fcp2       2f:97:00:a0:98:0b:56:13
Displays the WWPNs for each FCP logical interface for all the Vservers in a cluster.
