cluster add-node-status-clear-failed
Remove failed nodes from the status list
The cluster add-node-status-clear-failed command removes failed entries from the status list displayed by the cluster add-node-status command.
The following example removes failed entries:
clus1::> cluster add-node-status
Node Name Cluster IP Status Error Reason
- 2.2.2.2 failure The cluster port MTU
values do not match.
Retry cluster create or
join after updating the
cluster port MTUs to the
same value.
node1 1.1.1.1 success
2 entries were displayed.
clus1::> cluster add-node-status-clear-failed
node1 1.1.1.1. success
