      cluster add-node-status-clear-failed
Remove failed nodes from the status list
The cluster add-node-status-clear-failed command removes failed entries from the status list displayed by the cluster add-node-status command.
The following example removes failed entries:
clus1::> cluster add-node-status
        Node Name        Cluster IP          Status              Error Reason
        -                2.2.2.2             failure             The cluster port MTU
        values do not match.
        Retry cluster create or
        join after updating the
        cluster port MTUs to the
        same value.
        node1            1.1.1.1             success
        2 entries were displayed.
clus1::> cluster add-node-status-clear-failed
        node1            1.1.1.1.            success
 PDFs
PDFs
