vserver cifs home-directory search-path add
Add a home directory search path
The vserver cifs home-directory search-path add command adds a search path to a CIFS home directory configuration.
-vserver <vserver name>- Vserver-
This parameter specifies the CIFS-enabled Vserver containing the CIFS home directory configuration to which you want to add the search path.
-path <text>- Path-
This parameter specifies the search path you want to add.
The following example adds the path /home1 to the CIFS home directory configuration on Vserver vs1.
cluster1::> vserver cifs home-directory search-path add -vserver vs1 -path /home1
