ONTAP commands
lun igroup show
Display a list of initiator groups
This command displays status information for initiator groups (igroup). By default, the command displays status for all initiator groups.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver Name
Specifies the Vserver.
[-igroup <text>] - Igroup Name
Selects the initiator groups that match this parameter value.
[-protocol {mixed|fcp|iscsi}] - Protocol
Selects the initiator groups that match this parameter value (FCP , iSCSI , or mixed ).
[-t, -ostype <Initiator Group OS Type>] - OS Type
Selects the initiator groups that match this parameter value. The operating system types are
  • solaris
  • windows
  • hpux
  • aix
  • linux
  • netware
  • vmware
  • openvms
  • xen
  • hyper_v
[-a, -portset <text>] - Portset Binding Igroup
[-initiator <text>,…​] - Initiators
[-child-igroups <text>,…​] - Child Igroups
[-uuid <UUID>] - Igroup UUID
[-delete-on-unmap {true|false}] - Delete on Last Unmap
Selects the initiator groups that match this parameter value. A value of true displays all the initiator groups that will be deleted automatically when they are no longer used in a LUN mapping relationship.
[-comment <text>] - Igroup Comment
Selects the igroups that match this parameter value.
cluster1::> igroup show -instance
          Vserver Name: vs0
           Igroup Name: ig1
              Protocol: mixed
               OS Type: linux
Portset Binding Igroup: -
           Igroup UUID: 358338ba-cfd6-11df-a9ab-123478563412
            Initiators: iqn.1992-08.com.mv:abc (not logged in)
Vserver Name: vs0
           Igroup Name: ig2
              Protocol: mixed
               OS Type: linux
           Igroup UUID: 3fb136c7-cfd6-11df-a9ab-123478563412
            Initiators: -
Vserver Name: vs1
           Igroup Name: ig1
              Protocol: mixed
               OS Type: windows
Portset Binding Igroup: p1
           Igroup UUID: 03accf6b-d08c-11df-a9ab-123478563412
            Initiators: -
3 entries were displayed.
The example above displays information about all initiator groups.
