lun igroup show
Display a list of initiator groups
This command displays status information for initiator groups (igroup). By default, the command displays status for all initiator groups.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver Name-
Specifies the Vserver.
[-igroup <text>]- Igroup Name-
Selects the initiator groups that match this parameter value.
[-protocol {mixed|fcp|iscsi}]- Protocol-
Selects the initiator groups that match this parameter value (
FCP,iSCSI, ormixed). [-t, -ostype <Initiator Group OS Type>]- OS Type-
Selects the initiator groups that match this parameter value. The operating system types are
solaris -
windows -
hpux -
aix -
linux -
netware -
vmware -
openvms -
xen -
hyper_v
[-a, -portset <text>]- Portset Binding Igroup-
[-initiator <text>,…]- Initiators-
[-child-igroups <text>,…]- Child Igroups-
[-uuid <UUID>]- Igroup UUID-
[-delete-on-unmap {true|false}]- Delete on Last Unmap-
Selects the initiator groups that match this parameter value. A value of
truedisplays all the initiator groups that will be deleted automatically when they are no longer used in a LUN mapping relationship. [-comment <text>]- Igroup Comment-
Selects the igroups that match this parameter value.
[-replication-peer <text>]- Replication Peer-
Selects the initiator groups that match this parameter value. The replication-peer is the local name of the peer Vserver, as reported by the vserver peer show -fields peer-vserver command. When set, the igroup and any lun maps to LUNs in SMBC relationships are replicated to the peer cluster.
[-replication-error <text>]- Replication Error-
Selects the initiator groups that match this parameter value. This field provides information about asynchronous errors encountered while replicating this igroup. Igroups within a peering relationship are replicated in the same stream, so the error reported here might be related to this igroup or a prior replicated igroup that is now blocking the replication of this igroup. Both the error information and the igroup encountering the error are reported. If the error is configuration related, it can be corrected on the referenced igroup. The replication is retried using exponential backoff up to a maximum of one retry every 5 minutes. Every operation on the same stream triggers an immediate retry and restarts the exponential backoff starting with a 1 second delay. If the error is system related, the retries should correct the error when the system enters a healthy state.
[-replication-error-igroup <text>]- Replication Error Igroup-
Selects the initiator groups that match this parameter value. The name of the igroup encountering the error reported by the 'replication-error' field.
[-replicated-igroup-unreplicated-luns {true|false}]- Replicated Igroup Contains Unreplicated LUNs-
Selects the initiator groups that match this parameter value. This field indicates that the initiator group is replicated but contains one or more unreplicated LUNs.
cluster1::> igroup show -instance
Vserver Name: vs0
Igroup Name: ig1
Protocol: mixed
OS Type: linux
Portset Binding Igroup: -
Igroup UUID: 358338ba-cfd6-11df-a9ab-123478563412
Initiators: iqn.1992-08.com.mv:abc (not logged in)
Vserver Name: vs0
Igroup Name: ig2
Protocol: mixed
OS Type: linux
Igroup UUID: 3fb136c7-cfd6-11df-a9ab-123478563412
Initiators: -
Vserver Name: vs1
Igroup Name: ig1
Protocol: mixed
OS Type: windows
Portset Binding Igroup: p1
Igroup UUID: 03accf6b-d08c-11df-a9ab-123478563412
Initiators: -
3 entries were displayed.
The example above displays information about all initiator groups.
