vserver cifs check
Display Validation Status of CIFS Configuration from Each Node
Use the vserver cifs check command to check the status of configured CIFS server on a particular vserver.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
Use this parameter to specify the Vserver whose CIFS server needs to be validated.
[-node {<nodename>|local}]- Node-
Use this parameter to specify the node name from which CIFS server connectivity needs to be validated.
[-netbios-name <TextNoCase>]- CIFS NetBIOS Name-
Use this parameter to display netbios-name of the configured CIFS server.
[-cifs-status <TextNoCase>]- CIFS Server Status-
Use this parameter to display status of configured CIFS server.
[-site <TextNoCase>]- CIFS Server Site-
This parameter specifies the site discovered from Data ONTAP for the Active Directory domain associated with the CIFS server. If the discovery fails, this parameter will be updated with the default-site of associated cifs server.
[-server <TextNoCase>]- Domain Controller Name-
Use this parameter to display Domain name of the configured CIFS server.
[-server-ip <text>]- Domain Controller IP Addr-
Use this parameter to display IP-address of the configured CIFS server.
[-status {down|up}]- Connectivity Status-
Use this parameter to display information only about CIFS servers with a status that matches the value you specify.
[-status-details <text>]- Connectivity Status Details-
Use this parameter to display information only about CIFS servers with status details that match the value you specify.
The following example checks the connectivity of CIFS server on vserver vs0 from each node.
cluster1::> vserver cifs check -vserver vs0
Vserver : vs0
Cifs NetBIOS Name : NEWSERVER
Cifs Status : up
Site : Bangalore
Node Name DC Server Name DC Server IP Status Status Details
node1 CIFSSERVER.COM 10.11.12.13 up Response time (msec): 55
node2 CIFSSERVER.COM 10.11.12.13 up Response time (msec): 70
node3 CIFSSERVER.COM 10.11.12.13 down Secd: No Server available.
