Command reference
vserver cifs check
Display Validation Status of CIFS Configuration from Each Node
Use the vserver cifs check command to check the status of configured CIFS server on a particular vserver.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
Use this parameter to specify the Vserver whose CIFS server needs to be validated.
[-node {<nodename>|local}] - Node
Use this parameter to specify the node name from which CIFS server connectivity needs to be validated.
[-netbios-name <TextNoCase>] - CIFS NetBIOS Name
Use this parameter to display netbios-name of the configured CIFS server.
[-cifs-status <TextNoCase>] - CIFS Server Status
Use this parameter to display status of configured CIFS server.
[-site <TextNoCase>] - CIFS Server Site
This parameter specifies the site discovered from ONTAP for the Active Directory domain associated with the CIFS server. If the discovery fails, this parameter will be updated with the default-site of associated cifs server.
[-server <TextNoCase>] - Domain Controller Name
Use this parameter to display Domain name of the configured CIFS server.
[-server-ip <text>] - Domain Controller IP Addr
Use this parameter to display IP-address of the configured CIFS server.
[-status {down|up}] - Connectivity Status
Use this parameter to display information only about CIFS servers with a status that matches the value you specify.
[-status-details <text>] - Connectivity Status Details
Use this parameter to display information only about CIFS servers with status details that match the value you specify.
The following example checks the connectivity of CIFS server on vserver vs0 from each node.
cluster1::> vserver cifs check -vserver vs0
Vserver : vs0
                 Cifs NetBIOS Name : NEWSERVER
                       Cifs Status : up
                              Site : Bangalore
Node Name DC Server Name    DC Server IP  Status  Status Details
node1     CIFSSERVER.COM    10.11.12.13    up     Response time (msec): 55
node2     CIFSSERVER.COM    10.11.12.13    up     Response time (msec): 70
node3     CIFSSERVER.COM    10.11.12.13    down   Secd: No Server available.
