vserver fpolicy persistent-store modify
Modify a persist store
The vserver fpolicy persistent-store modify command modifies an FPolicy persistent store.
-vserver <Vserver Name>- Vserver-
This parameter specifies the name of the Vserver on which you want to modify an Fpolicy persistent store.
-persistent-store <text>- Persistent Store Name-
This parameter specifies name of the Fpolicy persistent store that you want to modify.
[-volume <text>]- Volume name of the Persistent Store-
This parameter specifies volume name for the Fpolicy persistent store.
The following example modifies an FPolicy persistent store.
cluster1::> vserver fpolicy persistent-store modify -vserver vs1.example.com -persistent-store ps1 -volume psvol
cluster1::> vserver fpolicy persistent-store show -vserver vs1.example.com -persistent-store ps1
Vserver: vs1.example.com
Persistent Store Name: ps1
Volume name of the Persistent Store: psvol
