vserver fpolicy policy scope delete
PDF of this doc site
Creating your file...
Your file is ready
Delete scope
The vserver fpolicy policy scope delete
command deletes an FPolicy policy scope.
-vserver <Vserver Name>
- Vserver-
This parameter specifies the name of the Vserver from which you want to delete the FPolicy policy scope.
-policy-name <Policy name>
- Policy-
This parameter specifies the name of the FPolicy policy for which you want to delete the scope.
The following example deletes a scope of an FPolicy policy.
cluster1::> vserver fpolicy policy scope delete -vserver vs1.example.com -policy-name vs1_pol
