vserver fpolicy policy scope delete
Delete scope
The vserver fpolicy policy scope delete
command deletes an FPolicy policy scope.
-vserver <Vserver Name>
- Vserver-
This parameter specifies the name of the Vserver from which you want to delete the FPolicy policy scope.
-policy-name <Policy name>
- Policy-
This parameter specifies the name of the FPolicy policy for which you want to delete the scope.
The following example deletes a scope of an FPolicy policy.
cluster1::> vserver fpolicy policy scope delete -vserver vs1.example.com -policy-name vs1_pol
