vserver fcp nameserver show
Display FCP fabric name server entries
This command show entries in the fabric name server database.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver-
Use this parameter to select the Vservers that contain FCP LIFs.
[-lif <text>]- LIF Name-
Use this parameter to select the FCP LIFs.
[-port-id <Hex Integer>]- Port Identifier-
Use this parameter to select the assigned port identifier of the LIF.
[-unzoned <true>]- Show unzoned name server entries-
Use this parameter to show unzoned name server information.
[-port-type <text>]- Port Type-
Use this parameter to select the port type of the LIF.
[-port-wwn <text>]- Port WWN-
Use this parameter to select World Wide Port Name (WWPN) of the LIF.
[-fabric-port-wwn <text>]- Fabric Port WWN-
Use this parameter to select the fabric World Wide Port Name (WWPN) of the lif.
[-node-wwn <text>]- Node WWN-
Use this parameter to select the World Wide Node Name (WWNN) of the LIF.
[-service-class <text>]- Service Class-
Use this parameter to select the registered class of services as defined in the FC-FS standard.
[-fc4-type <text>]- FC4 Type-
Use this parameter to select the registered FC4 type.
[-switch-port <text>]- Switch Port-
Use this parameter to select the name of switch port connected to target array.
cluster1::> vserver fcp nameserver show
Port Port FC4
Vserver:Lif Node WWN, Port WWN Id Type Type
vs1 :lif1
20:00:00:a0:98:55:73:38
20:01:00:a0:98:55:73:38 8130561 N-Port FCP
20:00:00:90:fa:73:12:dd
10:00:00:90:fa:73:12:dd 8194560 N-Port
vs1 :lif2
20:00:00:90:fa:94:29:ee
10:00:00:90:fa:94:29:ee 8201984 N-Port FCP
3 entries were displayed.
