vserver fcp nameserver show
Display FCP fabric name server entries
This command show entries in the fabric name server database.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver-
Use this parameter to select the Vservers that contain FCP LIFs.
[-lif <text>]
- LIF Name-
Use this parameter to select the FCP LIFs.
[-port-id <Hex Integer>]
- Port Identifier-
Use this parameter to select the assigned port identifier of the LIF.
[-unzoned <true>]
- Show unzoned name server entries-
Use this parameter to show unzoned name server information.
[-port-type <text>]
- Port Type-
Use this parameter to select the port type of the LIF.
[-port-wwn <text>]
- Port WWN-
Use this parameter to select World Wide Port Name (WWPN) of the LIF.
[-fabric-port-wwn <text>]
- Fabric Port WWN-
Use this parameter to select the fabric World Wide Port Name (WWPN) of the lif.
[-node-wwn <text>]
- Node WWN-
Use this parameter to select the World Wide Node Name (WWNN) of the LIF.
[-service-class <text>]
- Service Class-
Use this parameter to select the registered class of services as defined in the FC-FS standard.
[-fc4-type <text>]
- FC4 Type-
Use this parameter to select the registered FC4 type.
[-switch-port <text>]
- Switch Port-
Use this parameter to select the name of switch port connected to target array.
cluster1::> vserver fcp nameserver show Port Port FC4 Vserver:Lif Node WWN, Port WWN Id Type Type ------------------- ------------------------ -------- ------------ ------------ vs1 :lif1 20:00:00:a0:98:55:73:38 20:01:00:a0:98:55:73:38 8130561 N-Port FCP 20:00:00:90:fa:73:12:dd 10:00:00:90:fa:73:12:dd 8194560 N-Port vs1 :lif2 20:00:00:90:fa:94:29:ee 10:00:00:90:fa:94:29:ee 8201984 N-Port FCP 3 entries were displayed.
