ONTAP commands
vserver fcp nameserver show
Display FCP fabric name server entries
This command show entries in the fabric name server database.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver
Use this parameter to select the Vservers that contain FCP LIFs.
[-lif <text>] - LIF Name
Use this parameter to select the FCP LIFs.
[-port-id <Hex Integer>] - Port Identifier
Use this parameter to select the assigned port identifier of the LIF.
[-unzoned <true>] - Show unzoned name server entries
Use this parameter to show unzoned name server information.
[-port-type <text>] - Port Type
Use this parameter to select the port type of the LIF.
[-port-wwn <text>] - Port WWN
Use this parameter to select World Wide Port Name (WWPN) of the LIF.
[-fabric-port-wwn <text>] - Fabric Port WWN
Use this parameter to select the fabric World Wide Port Name (WWPN) of the lif.
[-node-wwn <text>] - Node WWN
Use this parameter to select the World Wide Node Name (WWNN) of the LIF.
[-service-class <text>] - Service Class
Use this parameter to select the registered class of services as defined in the FC-FS standard.
[-fc4-type <text>] - FC4 Type
Use this parameter to select the registered FC4 type.
[-switch-port <text>] - Switch Port
Use this parameter to select the name of switch port connected to target array.
cluster1::> vserver fcp nameserver show
                                                     Port     Port         FC4
        Vserver:Lif         Node WWN, Port WWN       Id       Type         Type
        vs1 :lif1
                           20:00:00:a0:98:55:73:38
                           20:01:00:a0:98:55:73:38   8130561  N-Port       FCP
                           20:00:00:90:fa:73:12:dd
                           10:00:00:90:fa:73:12:dd   8194560  N-Port
        vs1 :lif2
                           20:00:00:90:fa:94:29:ee
                           10:00:00:90:fa:94:29:ee   8201984  N-Port       FCP
        3 entries were displayed.
