The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver nvme subsystem modify
PDF of this doc site
Creating your file...
Your file is ready
Modify an NVMe target subsystem
The vserver nvme subsystem modify
command modifies an existing NVMe target subsystem.
-vserver <Vserver Name>
- Vserver Name-
Specifies the Vserver.
-subsystem <text>
- Subsystem-
Specifies the NVMe target subsystem.
[-comment <text>]
- Comment-
Contains a textual description of the NVMe subsystem.
[-delete-on-unmap {true|false}]
- Delete on Unmap (privilege: advanced)-
Specifies whether the subsystem should be deleted automatically when it is no longer mapped to a namespace.
cluster1::*> vserver nvme subsystem modify -vserver vs_1 -subsystem sub_1 -comment "Example Comment"
Modifies the comment on the subsystem named sub_1
on Vserver vs_1
