network bgp config show
Display BGP configuration
The network bgp config show command displays the border gateway protocol (BGP) configuration for each node.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
This parameter selects the BGP configurations that match the specified node.
[-asn <integer>] - Autonomous System Number
This parameter selects the BGP configurations that match the specified autonomous system number.
[-hold-time <integer>] - Hold Time
This parameter selects BGP configurations that match the specified hold time.
[-router-id <IP Address>] - Router ID
This parameter selects the BGP configurations that match the specfied router ID.
cluster1::> network bgp config show
        Autonomous
        System    Hold Time
    Node    Number    (seconds)  Router ID
    node1    10    180    10.0.1.112
