network bgp config show
Display BGP configuration
The network bgp config show
command displays the border gateway protocol (BGP) configuration for each node.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
This parameter selects the BGP configurations that match the specified node.
[-asn <integer>]
- Autonomous System Number-
This parameter selects the BGP configurations that match the specified autonomous system number.
[-hold-time <integer>]
- Hold Time-
This parameter selects BGP configurations that match the specified hold time.
[-router-id <IP Address>]
- Router ID-
This parameter selects the BGP configurations that match the specfied router ID.
cluster1::> network bgp config show Autonomous System Hold Time Node Number (seconds) Router ID --------------- --------------- --------------- --------- node1 10 180 10.0.1.112
