network bgp config show
PDF of this doc site
Creating your file...
Display BGP configuration
The network bgp config show
command displays the border gateway protocol (BGP) configuration for each node.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
This parameter selects the BGP configurations that match the specified node.
[-asn <integer>]
- Autonomous System Number-
This parameter selects the BGP configurations that match the specified autonomous system number.
[-hold-time <integer>]
- Hold Time-
This parameter selects BGP configurations that match the specified hold time.
[-router-id <IP Address>]
- Router ID-
This parameter selects the BGP configurations that match the specfied router ID.
cluster1::> network bgp config show Autonomous System Hold Time Node Number (seconds) Router ID --------------- --------------- --------------- --------- node1 10 180 10.0.1.112
