system controller platform-capability show
Display platform capabilities
The system controller platform-capability show command displays information about all platform capabilities for each controller in the cluster. By default, the command displays the following information about all controllers in the cluster:
Controller Name
Capability ID
Capability Supported?
Capability Name
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
Displays detailed information about all controllers in the cluster.
[-node {<nodename>|local}]- Node-
Selects information about the specified controller.
[-capability-id <integer>]- Capability ID-
Selects the desired capability ID.
[-supported <text>]- Supported?-
Selects the desired capability support state (true or false).
[-name <text>]- Capability Name-
Selects the desired capability name.
The following example displays platform capability information for the controller:
cluster1::> system controller platform-capability show
Node Capability ID Supported? Capability Name
or-099-diag-01
0 false CAP_CMCI_ENABLED
1 false CAP_HA_CONFIG_ONLY
2 true CAP_SUPPORT_CARD_FRU
3 true CAP_SCORPIO_EN
4 false CAP_NVD_EN
5 false CAP_ENABLE_HPET
6 false CAP_VERIFY_ACPI_TABLE
7 entries were displayed.
