ONTAP commands
network port vlan show
Display virtual LANs (VLANs)
The network port vlan show command displays information about network ports that are attached to VLANs. The command output indicates any inactive links and lists the reason for the inactive status.
If the operational duplex mode and speed cannot be determined (for instance, if the link is down), they are listed as undef , meaning undefined.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects the VLAN network ports that match this parameter value.
{ [-vlan-name {<netport>|<ifgrp>}] - VLAN Name
| [-port {<netport>|<ifgrp>}] - Associated Network Port
Selects the VLAN network ports that match this parameter value. If neither this parameter nor -name are used, the command displays information about all network ports.
[-vlan-id <integer>] - Network Switch VLAN Identifier }
[-mac <MAC Address>] - MAC address
The example below shows VLAN e1b-70 attached to port e1b on node1.
cluster1::> network port vlan show
                 Network Network
Node   VLAN Name Port    VLAN ID  MAC Address
node1  e1b-70    e1b     70       00:15:17:76:7b:69
