      storage firmware disk delete
Delete a disk firmware file
The storage firmware disk delete command deletes the specified disk firmware file on each node.
-filename <text>- Storage Firmware Filename (privilege: advanced)-
Specifies the firmware file to delete.
The following example deletes the disk firmware file with the name X262_SMOOST25SSX.NA06.LOD on each node:
cluster1::*> storage firmware disk delete -filename X262_SMOOST25SSX.NA06.LOD
