      system node image package delete
Delete a software package
The delete command will delete the specified software package.
- -node {<nodename>|local}- Node (privilege: advanced)
The package will be deleted from the repository belonging to the node specified with this parameter. The local node is used as the default if this parameter is omitted.
- -package <text>- Package File Name (privilege: advanced)
This parameter specifies the package to be deleted.
::> system image package delete image.tgz 1 entry was deleted.
 PDFs
PDFs
